Hello, ppl out there, this is Shawn Baek studying automotive engineering at Kookmin University in South Korea.
I'm in charge of pedal box and brake system for 2014 F-SAE Michigan. but currently i have some problems with master cylinder.
I set up master cylinders which i bought from Wilwood to our car and finished bleeding the brake system.
after test driving, i checked if there was any oil leak from the master cylinders and i noticed the brake oil was leaking along the push rod!!!!
it shouldn't happen but it actually did..............
so i switched it to the new one and it ended up happening again.
I'm kinda frustrated now and there is no one around me knowing the answer.
that's why i'm posting this now.
does anybody here know what the problem is and why it happened?
BTW, the push rod is being actuated at no angle.
Thank you for reading this and I wish all the best for your team!
