The Flatshifter Max gear shift system is designed for all makes and models of motorcycle engines and is supplied as a universal system with many in use by FSAE teams. so if/when you change your motorcycle engine or build next years new car just remove the Max electric gearshift kit, & refit to your new machine, this kit has proven its reliability in over 10 years of manufacture with 1000`s of kits in regular daily use.
This system is now also available for all race & rally cars. using sequential transmissions.
The benefits of the Flatshifter Max gear System are significant; the driver can fully focus on his driving and doesn’t need to bother operating the gear-lever.
Operated by two discreet buttons - usually mounted on the steering wheel which sit conveniently beneath the thumb, optional gearshift paddles available.
Improving concentration and safety
The Flatshifter max kit is powered by the electrical system on your race car, unlike air shifters, once fitted there is virtually no maintenance required, no bulky gas bottles to fill.
It is dual acting for both up & down shifts, and is very fast and consistent - typically 35 - 50 milliseconds on Japanese gearboxes.
Even more benefits can be added to the Flatshifter Max electric gear shift selector System, it can also be used in combination with our clutch-less up-shift & clutchless down gear-shift systems (Flatshifter Pro & Expert system) which results in a significant reduction in lap times, as well as reduced gearbox/clutch & chain wear. Change up & down the gears without touching the gear lever or operating the clutch!!
FULL DETAILS AT WWW.FLATSHIFTER.COM
As far as our thoughts on the Flatshifter: The Flat Shifter Max is a great solution for our car, it enables us to shift rapidly and reliably in competition. It has proved much more effective than previous shifters we’ve tried.
Thanks
Luca Martinelli
EDE Team Leader10524371_10154416608035026_37588506655598477 30_n
Cardiff Racing
GEARSHIFT PADDLES ALSO AVAILABLE.
Other flatshifter products
For racers, leisure & disabled riders/drivers
Flatshifter Club Full or part throttle clutchless up gearshifts.
Flatshifter Pro Full or part throttle clutchless up & clutchless down gearshifts with autoblip system. only
Flatshifter Expert Full or part throttle clutchless up & clutchless down gearshifts (race version of Pro above)
Flatshifter Max Electric solenoid gearshift system operated by buttons or Paddles.
Flatshifter Paddles For all electric & pneumatic gear shift systems only
