Results 1 to 10 of 17
Thread: Electric forced induction?
    Just stumbled upon a picture of an electric supercharger from the Hercules Racing Team Kassel on Facebook (https://www.facebook.com/photo.php?f...levant_count=1). This reminded me of an old discussion we had on the forums, on the "fantasy engine" thread.
    Quote Originally Posted by mech5496 View Post
    ...IMO energy recovery from a turbocompound would be minimal, and most probably dependent on the load/RPM, as it is a mechanical system. What about using it in combination with an alternator? That way you could use exhaust gas energy to produce electricity. Get rid of (mechanical) water and oil pumps and replace them with electric ones should free some power. I know, conversion of mechanical to electric energy would lower the efficiency a bit, but IMO you would have greater control over recovered energy. Alternatively, you can do the above powered by recovered energy from braking (small front hub motors) plus turbocompound.
    What about an electric turbo? You could run it entirely on recovered energy, no backpressure, complete control over boost, zero lag etc..
    I was re-thinking the latter, i.e. use small electric motors in front hubs to store on-board electric energy, then use that energy to power an electric turbocharger. This would help efficiency a bit plus all benefits from a control point of view, packaging etc. IMO this arrangement should still classify the car as a IC and not a "hybrid". What do you guys think?
    While we're at it: use thermocouples / thermoelectric generators at the exhaust heat to generate some power. Low efficiency but it 'free'.
    Tristan
    Delft '09 Team member, '10 - Chief Electronics
    'now' (Hardware) Security Engineer
    I think you would have a hard time selling the vehicle as a non-hybrid, even if the motors are tiny. The easiest way to get some extra energy would probably just be a few extra battery cells. Boring, but effective.
    Definitely like the idea, but it follows the same thought process as using an electric instead of shaft/belt driven water pump. Is the power you save/make worth the extra electrical draw and its associated weight? The packaging woes? The nightmares about not restarting at driver change? Personally, I shy away from these type of projects because they're usually someone's bright idea who didn't totally think it through. That's not to say it couldn't be done - and done well - but it just seems like a lot of effort for minimal gain. At least for FSAE
    Owen Thomas
    Owen, I was thinking the front motors (actually generators as they will be used to charge an accumulator and not for propulsion, in order to classify as an IC) producing 1-2kW. Using them in around 20% per lap recuperates significant amount of energy.
    Now the best possible (i.e. more efficient) way to use that energy would be converting it directly back to kinetic energy when you need it, using something like "electric turbo-compounding" or using the front motors for propulsion too. It would operate like a KERS system; use the recuperated energy to boost corner exit for instance. I'm quite sure this would classify as a hybrid though...
    So to get away from hybrids, just use the recuperated energy to boost the engine! You can also free up some extra engine power by removing auxiliaries like alternator, oil and water pump.
    Quote Originally Posted by Owen Thomas View Post
    ...it follows the same thought process as using an electric instead of shaft/belt driven water pump. Is the power you save/make worth the extra electrical draw and its associated weight?
    Well, not really. The idea behind using an electric water pump is that it operates in a certain RPM in which it works efficiently. When using a mechanical pump, losses increase with increased engine RPM. Therefore you use some of the engine power to feed the alternator which converts mechanical to electric energy, then store that very energy on a battery and use it to power the pump. Because neither the alternator nor the pump motor have a 100% efficiency, you dumb away a fair amount of energy in the form of heat throughout the process; and you hope the gains from removing the inefficient in high RPM mechanical pump are more than the losses from the (double) energy conversion, which I doubt. The idea behind my proposed idea is using kinetic energy, otherwise dumped from the brakes in the form of heat every time you press the brake pedal, to power all these systems which would need engine power and fuel in order to work. I will try to quantify these gains in the next few days.
    By using small DC motors, the system gets much simpler (no need for a complicated AC/DC converter). DC brushless motors can get really small and light, take a look at ThinGap for instance (http://www.thingap.com/standard-products/). Way less than a kilo per motor and their ring-like design makes them easy to package in the upright/hub assembly, possibly in between the bearings. Also the total accumulator capacity should not be that high, as it is constantly charged when braking, therefore its' weight could be kept relatively low.
    Tristan, I like your idea of thermoelectric generators, need to do a bit of research on those to see if you can really gain something. Would you like to give me a hand on that?
    Oct 2009
    San Antonio, TX
    467
    Did the team from Kassel end up running the electric supercharger on their car or was it relegated to design presentation table adornment?
    Matt Birt
    If someone will try to implement the front generators idea than they should definitely check back with the rules committee of the respective competition.
    A thing that always baffles me is that there is no voltage limit for the electric system of the combustion cars. A 600V system will probably be rejected at scrutineering, but there is no rule prohibiting that.
    Regards,
    Tobias
    Formula Student Germany
    FSE Rules & Organisation
    http://twitter.com/TobiasMic
    http://TobiasMic.Blogspot.com
    Memory says Cal State Poly Pomona won the 2000 Formula Student competition using an electrically driven supercharger.
    I think the major key as to whether a car is classed as a hybrid or not is the last phrase of IC1.1.1 which says ".., such as those using electric motors running off stored energy, are prohibited." It is the stored energy provision that counts.
    Would an IC car that only recovered energy from the front wheels (or any wheels) be classified a hybrid? I thought the intention of a hybrid was that it used electric power (recovered or on board) to drive the vehicle in parallel or serial (or a combination) with the IC engine? Energy recovery from the front wheels is surely just a more intelligent way of recovering and generating electricity which is and always will be required to power the control and auxiliary systems of the vehicle. It would be a sad day if a vehicle recovering energy from braking the front wheels, instead of an inefficient alternator type system a hybrid (imo).
    I'm thinking motors attached to the front wheels, a la delft. Although those ring motors look quite interesting. I doubt anyone would call the system to convert the wheel driven motor voltage (3 phase or DC) into a 12V (or other) voltage for the vehicle does not make it a hybrid, all the other IC car's already have such systems!
    ISGs on the other hand would make it a hybrid if used to put energy back into driving the car at any time other than for starting the engine.
    Now, this intelligent energy recovery from front wheels and turbo compounding sounds pretty exciting to me. perhaps run all electric auxiliaries because you likely won't be able to spend all the electricity you're able to recover each lap, and you'll find a few free torques all over the range (at the possible cost of some weight - do electric water and oil pumps usually weigh more than their mechanical counterparts? probably, considering the engines already been designed to carry them already)
    The electric supercharger (is that rules compliant?). Also brilliant, the advantages of electrically controlled boost have already been mentioned.
    I also like the thermoelectric generator idea. Although would this make the exhaust gas energy recovery less efficient? (probably negligible)? or is it harvesting the waste heat energy after the turbo? I just might do some research.
    Edit: just seen Michael Royce's reply regarding the running of electric motors from stored energy. This would ban electric superchargers then.
    Also... With some work, it might be possible to use the front wheel energy recovery braking to maximise the front two wheels lateral and braking efforts on corner entry. No more locking the inner unloaded wheel (effectiveness probably dependent on the front LLTD?) Some kinematics guys will have to comment on how beneficial if at all this would be, but entirely possible electronically.
    Electronics Warwick Racing 11' Alumni
    Quote Originally Posted by Michael Royce View Post
    At some point in time the energy has to be stored and afterwards the car would be running of stored energy, if it releases the energy back into the front motors for example. Otherwise we would have to insert an energy meter in these cars to make sure that they only draw energy from the front motors, but never supply them.
    So am I right that regenerating energy from the front wheels for example would be ok, if it is not stored and later being used to propel the car directly through an electric motor? Because in industry this is considered a "street coupled hybrid".
    Regards,
    Tobias
    What about using a turbo as a generator instead of as forced induction? I'm not entirely sure how one could go about this, but then you could have similar benefits to the front wheel energy recovery.
