I was ball-parking the numbers earlier...should probably go back and change that. I always try and shoot for 1 lambda and it seems like the close loop control will account for any variance in the quality and octane. This last year at comp I wasn't seeing a change in our logged lambda-load maps from comp vs testing here at home.Originally posted by Mbirt:
Excellent post, John. I've got a few things to add.
The stoichiometric AFR for the E10 gasohol at competition is closer to 14.1:1. Some ECU's might place greater priority on this parameter than others. For E85, it's 9.76:1, but who knows if we'll get E75, E82, or what. It'll be numerically higher than 9.76.
I got the idea from my experience with flying. Having a mixture knob on the dash is always great! closest i could get without making it super technical was the switch It also works great if you're having trouble starting and suspect it might be flooded out. Also we usually kill the engine with it to keep fuel from pooling up on the back side of the valve. Kind of nice to have it, i use it more often than not.I liked your idea about cutting injector power while calibrating the cranking PW. To further fine-tune it from there, you'll know it's too much fuel if significant throttle opening helps it start. If it doesn't start regardless of throttle opening, it's too little fuel.
As previously mentioned we're running an M84 (little brother to the M400) and I've got the option to adjust INJ timing real time but just eliminated the table axis and set it at 300*BTDC. I haven't had the chance yet to fully exploit that ECU and tune it in as well as it should be. I've got to design our cooling, electrical and get a running engine in one year so it gets a little crammed I did have another Sparky join up though and a few other Mechy's so I'm hoping I'll have a little more dyno time this year.Teams not running 600/4's will want to exercise extra care when formulating an ignition base map. Check out the chapters on ignition and EFI in A. Graham Bell's "Four Stroke Performance Tuning". Your engine isn't running as restricted as a 600/4 and will not be as tolerant of over-advanced spark timing and lean running at high load. Our single on E85 likes less advance than the stock bike's module gave at "all in".
Question for you guys: Do you have any rules of thumb for timing the injection event? Our ECU has a nice, big load vs RPM map for the start of injection angle, but it can't be calibrated in real time. Changes must be made offline, a new ECU program must be compiled and flashed--tedious. I can, however change the phase angle of the entire map and it made a significant difference on the engine dyno by shifting trouble spots at various loads to new speeds. I would really prefer a calibratible end of injection angle map.
