Hi there, we are planning a toothed-belt final drive. 1:3.6 reduction with 80kw peak power electric motor (217Nm; 3360rpm top values). A belt company has done some calculations. They gave us, 88mm diameter pinion and 285mm diam sprocket pulleys. (3kg and 12kg weight). This is unacceptable for any team. So where can I find a good belt without 15kg weight pulleys?
