I'm trying to come up with an alternative design for our front uprights. currently we are set to use steel tubing with attachment points welded on the main piece. After some consideration and hopefully some inovation as well I've come up with a design that I think will suit our team much better (ie more adjustability with less work). I know it depends on many factors but I'm just curious what thickness of material, 6061, teams are using for this type of process.
Secondly, for teams that are shimming the top of their front upright for camber adjustmentsare you using wedge shapped shimms to keep from moving your roll center when you go from say one degree of camber to 4 degrees. If not are you setting up the system to have the ideal roll center for camber settings that your would prefer for events like the autocross and endurance. Therefor just accepting the suspension as is with the adjusted camber for other events like the acceleration and skid pad.
And lastly, would a press fit for the spindle be enough assuming a tight tolerance with a "nail type head" comming from the inboard side of the upright?
Cheers
