This is mohamed aboelfadl the electronics guy from Cairo university team
KTM exc 450 2012 is having issues trying to start. We checked the spark and injectors but they work once during crancking then they stop. We are using the stock control unit along with the stock wiring harness
We tried the following procedures:
Hooking to a diagnosis tool showed good rpm.
Changed pulser coil but the same issue.
Trying our ecu on another bike and it worked.
Manually actuating injectors and ignition through diagnosis tool they worked successfully.
Checking all fuses and grounds.
We are now suspecting the stator or rectifier as the last problem?
We tried removing the rectifier but there was no spark at all.
Any suggestions to try?
