KTM 500exc engine not starting!
Hello Everyone,
We've received a new ktm500 exc engine(2017 model), but are having some trouble starting it. Any kind of help would be appreciated. Thanks in advance.
What's wrong-
1) When we try to start the engine, the starter motor does cranks the engine but the engine does not starts.
2) We checked for spark, and just after pushing the crank button, a spark is seen but only once. After that throughout the crank, spark plug does not provide any spark. Confirmed this many times.
3) According to the wiring diagram, ecu/ voltage regulator should provide ground to power relay, but due to some reason it is not doing so. Anyway, we bypass the power relay and provide power to ecu and other electricals. The fuel pump also turns on for 3 seconds, but after that fuel pump does not works while cranking the engine.
What we've done-
1) Checked the injector.
When we try to crank the engine, it sprays fuel initially, but since the fuel pump is not working, fuel line loses pressure, and it stops spraying.
2) Cranked the engine with/without map and coolant temp sensor.
Some people on the forum had problems with running engine having one of the sensors plugged in, so we tried to run the engine with/without any of them. Sensors are working fine, engine still has the same problem.
3) Rollover sensor is in correct position.
4) Connected the dignostics tool, no fault codes found on ecu.
5) Checked the throttle position sensor, it is calibrated to standard values as in the manual.
6) Checked for the side stand sensor, no problem there.
7) Checked the ignition coil resistance. Resistance found corresponds to standard values.
8)Crank position sensor is working fine, since we were able to read engine rpm while cranking through dignostics port.
