<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by gaoleiHRT-China:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Kirby:
Photos of said destroyed joint? </div></BLOCKQUOTE>http://www.fsae-china.com/viewthread...id=1847&extra=
photos is here ,the destroyed poit is too horrible to look at.ahh http://www.fsae-china.com/view....php?tid=1847&extra= </div></BLOCKQUOTE>
Unfortunately, We cant view (we need to login), cant login (need to register) and can't register (need to be invited).
Without seeing the photo, but reading the (google translated) responses of those who have, sounds like a bolt tear out failure. But i'd like to see the photo first.
Why is there a bolt / pin in there?
I can see the images with that link fine by the way.
Two photos at:
http ://static16.photo.sina.com.cn/middle/6a0db8b7t937ddd06efdf&690
http ://static2.photo.sina.com.cn/middle/6a0db8b7t937ddd05df91&690
Drew
Are you using also a pin to fix the carbon tube to the alu insert?
What is the hole in the upper side of the carbon tube?
we hope a bolt can make the connection to be more powerful,but it does not work compoletely<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Drew Price:
Two photos at:
Drew </div></BLOCKQUOTE>
we hope to use a pin to make the connection to be more powerful.but it does not work compeletely,things we want to know is what glue we should use,and how use it!<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Lorenzo Pessa:
What is the hole in the upper side of the carbon tube? </div></BLOCKQUOTE>
I think you insert weak points making holes in the carbon tube.
If you can try to use only glue to fix the tube.
You can find bonding documentation on the website of Loctite.
For a good bonding it is important the surface preparation. a common error is to sand and clean.
the correct sequence is to clean the surfaces (use specific product or trichloroethylene, not other cleaners! they left impurity). then sand the surface, clean again.
