My name is Brian Lewis and I am one of the founders of Performance Electronics, Ltd., a small company that designs and produces engine
management systems. We have been working with several Formula SAE teams over the last 5 years and are interested in expanding our presence at this year's competition
We have a brand new design that will be available for this years competition. The system is small, lightweight, easy to tune and has many of the features that you would find in much higher priced units. In addition FSAE teams receive 20% discount off of the list price. This brings the total system price to only $760 USD. The features of the system are listed below.
In addition to the many great features of the system itself, Performance Electronics, Ltd. is committed to providing the best technical support
around. We have helped several first and second year teams make the transition to electronic control. The people that you talk to when you
call with a questions are the engineers who designed the hardware and software, not some new hire on a technical support hotline. Also, we have
sent at least one representative to the competition for the last five years to help with any last minute problems.
Please take a moment to visit our website at www.pe-ltd.com and check out the new system. A copy of the Installation/User's manual as well as the tuning software can be downloaded from the site. Just look under the "Support" heading at the top of the page. Thanks for your time. If you have any questions please feel free to call.
GENERAL FEATURES
-Complete fuel and ignition control for 1,4,6 and 8 cylinder engines up to 20,000 RPM
-Simple and intuitive Windows based tuning software
-Sturdy construction including waterproof automotive style connectors and
potted PCB
-Easy to use default table generation
-Data logging to the PC
-Linear interpolation within all tuning tables
-On the fly error code generation and capture
-On-line and context sensitive Help
-Real time plotting capabilities
-Battery transient protection
-Engines: 2 & 4-stroke
-Compact Size, just 4.8"L x 5.25"W x 2.13"H
FUEL SPECIFIC
-16x16 table of fuel values
-Starting, Battery Voltage, Air Temp, Coolant Temp and Acceleration
compensation
-Injector open angle control
-Load control via manifold pressure or throttle position
-Fuel pump control including initial priming
-Up to 3 generic analog inputs that can be used with any 0-5 volt sensor to
modify the fuel flow
IGNITION SPECIFIC
-16x16 table of ignition advance values
-Wasted spark or distributor for 4 cylinder engines
-Distributed ignition for 6 or 8-cylinder engines
-Adjustable dwell
-Air temperature compensation
-Rev limit
modify ignition timing
-The ability to drive aftermarket, capacitive discharge or multiple spark ignition boxes
INPUTS
-Standard GM sensor inputs
-Manifold pressure
-Throttle position
-Air Temperature
-Coolant Temperature
-Battery Voltage
-Crank Position
-3 user configurable analog inputs that can be used to modify fuel flow or ignition based on any sensor
-2 configurable digital inputs that can be set up to stop fuel, stop ignition or kill the engine
OUTPUTS
-4 saturated drivers for high impedance injectors (Injector resistance should be above 10 ohms)
-2 internal coil drivers (Coil resistance must be above 3 ohms)
-Fuel pump control
-4 user configurable digital outputs for turning devices on and off based on RPM, MAP, TPS, Air Temperature or Coolant Temperature
Brian Lewis
Engineering Partner
(513) 777-5233
GENERAL FEATURES
potted PCB
FUEL SPECIFIC
compensation
IGNITION SPECIFIC
-Adjustable dwell
-Rev limit
INPUTS
-Manifold pressure
-Throttle position
-Air Temperature
-Battery Voltage
-Crank Position
OUTPUTS
-Fuel pump control
Brian Lewis
Engineering Partner
(513) 777-5233
Check out the latest version of our tuning software on www.pe-ltd.com. The installation file can be downloaded from "Support".
